Do you guys think it would be beneficial to add a heat shield/deflector to my insert? At the time of the install I did not put a block off plate in. Maybe in the off season I will pull the stove and add one but for now, call me lazy, I really don't want to.
The chimney is roughly 20' tall with 16' being inside the house, directly in the center of the house. It's a huge, massive stone and brick column. So I did not go with an insulated liner. The stove is as far out of the firebox on the hearth as I can get it due to the liner connection.
On days when temps stay above the upper 20's I don't have a need to run the blower. But I feel there might be an opportunity to get even more radiant heat from this thing. I'm envisioning a 2 piece deflector above the stove with a half moon cut out of it to install around the liner. It would sit about 3 inches above the insert and extend over the back and sides to catch as much radiant heat as I could. It would extend outward into the room to meet the steel fire box. Sort of encapsulating the top 1/3 of the stove directing the heat out into the room.
Anyone ever do this? Pics, ideas, comments, other? I know these little blowers don't use much electricity but the less it runs the better.
