    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. gilly270 New Member
    west michigan
    i am looking for a 24"a snorkle kit for the old style heat n glo 5 & 8 dv pipe, any one have anything collecting dust in the warehouse.
    who the heck installs 14ft of horizontal with a 1 ft rise?
    #1
    Helpful Sponsor Ads!
  2. DAKSY Super Moderator
    I'm pretty sure the "Old Style" HnG pipe you're talking about was actually
    Simpson Dura-Vent 1200 series pipe. I'd try a Simpson dealer...
  3. Wood Heat Stoves Minister of Fire
    Nevada City, California
    i'm pretty sure the stuff he needs was made by hht, and has different ends than simpson
    i have one 24" section here, but its ends are beat up...
  4. gilly270 New Member
    west michigan
    yes the h-n-glo pipe was made slightly different than the simson 1200 series so you could only use the hht pipe.
  5. gilly270 New Member
    west michigan
    Dave, do you have a 24" pipe length or a 24" snorkle termination?
  6. Wood Heat Stoves Minister of Fire
    24" lenght, the ends could be straightened out i'd say
  7. DAKSY Super Moderator
    Ok. I stand corrected...
  8. Wood Heat Stoves Minister of Fire
    ^^ha, got ya for once :)
    i only knew for sure because i have an old stick here
  9. fireplace tech New Member
    northern, ohio
    that sounds like what we call d.v. pipe and yes there is an adapter through hht that can go from the old to the new , the pert # would be ad1 or ad2. if you are unable to find i can assist you . but i am pretty sure we still have some collecting dust .
  10. jtp10181 Minister of Fire
    Madison, WI
    Which old style of 5/8 pipe?
    There was VP pipe which has tab locks, the same as the current DVP but the locks go the opposite direction
    Before that there was a DV cinch pipe which had crimps on one end, or maybe this was only for Heatilator?
    At some time there was also what might be called DV-D which is a twist lock pipe by Simpson Duravent, and the OD is 8-5/8" (larger than the current 8" pipe).
    The only thing that you will find a snorkel for is the Simpson pipe. I might be able to order one if that's what you have, there would be no returns though, and it will be expensive. There was a never a snorkel cap made for the other two types of pipe that I am aware of.
    Can you take the current cap off and get a part number off the back of it? This would tell me what you have exactly.
