It's not much but I tok a lighter all around the door and the flame went nuts around the top left. It didn't go out. Can I just pull the roe gasket out a little bit or is there something else I should do?
The gaskets become compressed and need to be replaced over time. You should probably replace it at the end of the season, which is coming up very soon. I perform the same test on my gaskets, and they tend to last anywhere from one to three years before needing replacement.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
