    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. txiko New Member
    metrowest ma
    Hi:
    I have a Yankee Bay insert from Lopi and last night it stops feeding pellets.
    I had cleaned the hopper and put a few pellets and I can see the auger
    trying to spin. Any hep on how to address the problem?
    Thanks
    #1
    Helpful Sponsor Ads!
  2. txiko New Member
    metrowest ma
    All running again.
    The auger was stuck I have cleaned and I didn't realize
    that it takes between 7 to 10 minutes to work again.
    Thanks
  3. jtakeman Minister of Fire
    Northwestern CT.
    Shouldn't take that long to work again. Might be a plugged vacuum nipple/hose?
  4. txiko New Member
    metrowest ma
    It could be, I don't know I read about the time in
    a trouble shouting guide.
    The stove is working, what I noticed is that there are a lot more pellets in the fire pot now than before.
    Thanks
  5. imacman Minister of Fire
    Auger should start as soon as stove is turned on. It's possible that the connection between the auger motor and auger is loose.....there is a set screw that holds them connected. The set screw should be tightened against the flat part of the auger shaft....check it out.
