    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. The Maniac New Member
    Winterport Maine
    it seems to have less build up take me away guys and gals burnpot stays cleaner i need another beer ?
    #1
    Helpful Sponsor Ads!
  2. brack86svo New Member
    Central PA
    I would think it would just burn off rather quickly. I clean mine with a wire brush cup on a drill till its smooth and that seems to help. Maybe I'll try a little cooking spray. It will at least smell good while it's burning off.
  3. Mr. Spock Feeling the Heat
    SW MA
    Your beer goggles are on...have another beer.:p
  4. The Maniac New Member
    Winterport Maine
    i love beer u gotta try it what u have to lose ?
  5. The Maniac New Member
    Winterport Maine
    i have now done it severaL TIMES does it not work on a red hot grill ?
  6. Mr. Spock Feeling the Heat
    SW MA
    Just joshing with ya. Never tried it myself, like you say can't hurt.
  7. will711 Minister of Fire
    Pocono mts.
    ME TOO:cool:
    smoke show likes this.
  8. smoke show Minister of Fire
    Pittsfield, Wi
    did someone say beer?
  9. Bioburner Minister of Fire
    West central Mn
    I rubbed in graphite powder on a Santa Fe burn pot and bottom and worked well to keep the bottom from sticking. I would dust the bottom after every cleaning. Baby powder for pellet stoves:)
  10. DexterDay Minister of Fire
    NE Ohio
    Mmmmmm... Beer (this is happening again) !!!
    Me Three ;)
  11. smoke show Minister of Fire
    Pittsfield, Wi
    I like beer.
  12. schoondog Feeling the Heat
    dutchess county, n.y.
    Well grilling pam can't hurt and beer can't hurt either, so your good to go!!
    Doggy
  13. Bioburner Minister of Fire
    West central Mn
    Hickory or Mesquite?
  14. Brokenwing Feeling the Heat
    Northern Maryland
    Hmm what does the hearth forum and its members have in common. A derailed thread going to a beer discussion lmao!;)
  15. CT Pellet Minister of Fire
    Torrington, CT
    Spraying Pam on your burn pot will not hurt, but it will not help you either. Your efforts to prevent sticking are flawed because by the time the fire temps get hot enough to create the "fusions" that result in that hard build up, your Pam has been burned off quicker than Charlie Sheen. Like I said, it will not hurt, but spraying Pam on your burn pot to prevent sticking is about as helpful as bringing an accordian with you when you go duck hunting.
    opus74, schoondog and h2ochild like this.
  16. smoke show Minister of Fire
    Pittsfield, Wi
    Its ok to waste a little Pam here and there, but please do not waste beer.
    will711 likes this.
  17. whlago Feeling the Heat
    NW Connecticut
    Beer AND accordians.....sounds like an Italian hoedown!...someone bring the Olive Oil Pam!!
  18. imacman Minister of Fire
    Getting back to the serious side of this thread, a good replacement for the Pam would probably be a good coat of spray graphite or the dry moly spray. To do it right, the burn pot either needs to be brand new, or at least sand blasted down to bare metal.
    I've had VERY good luck with the spray graphite on my combustion motor fan blades & motor case.....the ash comes right off. When I run out of that, I'll give the dry moly spray a whirl.
    OK, NOW I'll have another Stella. hic
