couple of my wood/tree pics and vids, 56K beware
Freakingstang
262
Berlin Center, Ohio
New guy here... plenty of pics I will share. I'm a bit of a picture nazi.
a couple trees i took down on my "new" property this spring.
A pin oak outside of my back garage. was busting up the concrete in the garage and sick of the mess everywhere from it. i also wanted to put in a drive beside it for my trailer parking spot.
once it was on the ground, i found it had quite a bit of stump rot. I thought it was a healthy tree... all the southern half of the stump was gone, down the root canals and all.
Short video of it coming down. used a Stihl ported (modified) MS660 with a 28" bar. tree was about 32" at the stump. i cut the garage side first. click on the pic to start video
a half dead maple out in front of my house. All the alive weight was over the house..
another short video, click on pic to play video. I made the notch and started the back cut, then wedged it heavily on the house (weight) side. I used a Dolmar 7900 with a 25" bar. tree was about 29" right above the stump.
With the pic of the 4 saws. I have needed to use a second saw to cut one out in a bind, but that must have been a bad day to get all 4 stuck in a bind. I'm only joking.
Looks like fun
Very nice.
some milling pics of the oak. i decided to use my ported 660 and my 36" Grandberg MK3 mill instead of my totally brand new rebuilt 084 for this project.
Very nice pics.... Very nice Saws.... My In-laws live in the Canfield/Boardman area. I am just West of Akron.
Welcome, and we love pics... Keep them coming! :)
Reactions: ScotO
Love the pics, love the saws, love cutting risky trees......you'll fit right in around here, Freakingstang....
Those boards from the pin oak, that looks like some good rustic tabletop material there. How many boards did you end up with? How thick were they?
I've got several big oaks up on the ridge to drag out with my snowmobile, hoping to mill them as they are just waaay too nice to split up for firewood......
Welcome to the club!
Haven't figured out how to multiquote yet. i'm 10 min west of canfield, about 15 min to boardman. I"m new to this area from the center of the state. I bought a garage for my hobbies to live in and got a nice house with it. I work in akron.
that is exactly what I plan on doing with them. they are in my back garage drying out. I cut one slab at 3 1/2" thick. I wanted to make a thick coffee table. the boards are 9 feet long and the narrowest is 21-22" and the widest being 28. I did not mill the log into a cant as i was in a hurry to get it done. I got 6 boards 1 1/4" thick. and two that are 3 1/2" thick plus the last 4-5 inches of the last cant. i ran out of daylight. So i just stacked it all up and weighted it down,hoping I can keep it from warping too much. This was also my first time milling with my CSM that i've had for about 4 years now. i've moved a bunch and just hadn't had the time to use it. I thought the same thing, i had enough wood, and this was straight enough to make some decent lumber, plus what is neater than building something for your house out of wood you milled from your property? i had every intention of rolling the log to square it up, but i liked the grain I was seeing and kept going.
got tons of firewood out of the tree as it was without the bottom 9 feet...
Fiskars X27 does 98% of my splitting.
try stacking them (stickered, of course) and using some cheap Harbor Freight ratchet straps in three or four locations along the boards. Every month or so, go out and tighten the straps a click or two. Works good for small stacks.
I have around 300 bd ft of white oak boards, 300 bd ft of black walnut boards, and around 1000 bd ft of poplar drying out in my garage as we speak......my buddy has a 1940's era Frick roundblade mill powered by an ancient DT466 diesel powerplant, that'w what we use for milling....but I will own a Granberg mill someday for my Stihl 075.....
I have three big white pine saw logs on the trailer as I type this, and around 9 huge white oak logs still up on the ridge. I gotta make a skid to haul them out with the snowmobile....
Reactions: Thistle
might sound stupid. but how do I measure boardfeet? like I said, that was the first time i've used my mill and it ended up taking longer than I had thought. Ate about two gallons of fuel too.
And yes, i stickered it and weighted it down plus 4 straps down the lenght of the boards. approx ever 2-3 feet
so tell me, how'd you get that Rollomatic ES bar to mount up to your 372XP?....
just curious.
I have lots and lots of Stihls, but only one Husky (its a 372XP as well). What an awesome saw!
Looks like fun
haha, heres a long video of some ported saws. It was the first couple of tanks thru a MS360 I had just ported and was VERY impressed with it.. the 360 outcuts a stock 440/044 and a 372 husky. That 372 in the video has a TON of work done to it, almost too much for a work saw. you can hear the chain on it. The oiler hole got plugged up and wasn't oiling propperly.
just curious.
Baileys sells an adapter. The 372 has wider stud spacing that most other huskies. you have to use a small stihl mount (029-660). I had to mill the bar slot about 3/8"-1/2" forward to get enough room to get the chain on with a 8T rim. the oil holes line up. I have been running Stihl ES bars on all my huskies and Dolmars for years now. it was easier to have one type of bar that fit all the saws.. (well most). the adapter looks something like this:
This adapter is actually one I made for a Dolmar 7900. the stuf spacing is narrower than that on the husky 365/371/372. some of the aftermarket stihl bars have longer bar slots that work better with husky without modifying the bar. you can use a combination of a flat file and a chain file to elongate the hole if you don't have access to a drill press or mill. The bar adapter is about 10 bucks from Bailey's.
Does your 372 have a muffler mod yet? what size bar do you run on it? Opening up the muffler outlet and retuning helps tremendously, although it really takes well to porting...
Yep..... Its official. You are gonna be a well welcomed member. :)
how west of Akron? I grew up in wooster, lived in ashland/new london for a few years with the Ex and just recently lived in norton at the edge of clinton/barberton/wadsworth until I bought this place.
Actually in-between the Ashland/New London area. Live in Sullivan....
Well, now that I know about this adapter, I can start using my 20-some Stihl bars on the husky....thanks for the heads up! I have yet to mod the muffler on the 372xp yet, but I plan on doing so. Any pics of your muffler mod?
Dex is right, you're gonna fit in nicely around here!
here's my favorite....although the easiest way to to remove the muffler, remove sparkscreen, pry up on the deflector and get in there and diegrind the hole out.
Reactions: ScotO and Thistle
Nice lil' chunk of Black Cherry just behind the bar in last pic :cool: Really like that 'double barrel' muffler mod on that 372....I just bought a 2nd OEM deflector & firescreen & attached it on left side of my 288XPW with self tapping hex heads.
Reactions: ScotO
Yeah the 281/288 deflector is the other easy way. I do them on the stihls on the drivers side as well as the Dolmar 6400/7300/7900's.
Nice work Steve, love that Stihl bar on that Huskie. I was down your way just a bit ago to take my daughter to a friends near Palmyra and Bailey Rds. Came back home down Ellsworth from there but didn't see anything resembling your place. You must be east of Bailey on Ellsworth.
Welcome Aboard! Love the pics and video's!
Great pictures.
Nice set up.
Good info!
Just got your message, i'm about 1/4 mile west of duck creek (before bailey) to the south. Silver silverado in the drive. if you passed the kennel sign on the left, you went too far. I tell my car buddies to look for the stickered up mailbox until I get a Ford racing or Stihl sign hanging up.... lol.
Look for the tri-bar mustang running horse next christmas with the red white and blue..... Might do a blue ford oval in xmas lights too...
might have seen an episode of gold rush filmed last spring as I was regrading my property...got some wierd looks from the locals..... ya know, new guy in town, junk everywhere, cutting trees and fencelines down and then digging for gold?!!
Reactions: DexterDay
