Looking for recommendations on a reliable meter. Seen some pretty expensive ones out there but unsure what to get. Looking to spend between 20-40 dollars. Are there decent ones out there for that price?
I have the HF MM, but I have no idea how accurate is. It appears to be directionally correct (drier wood measure lower than wetter wood). I guess I could oven dry some wood and calculate the accuracy, but I don't have the time or inclination to do so....or a precision scale.
Unless I wanted to check the wood I was buying for moisture content (to make sure the "seasoned" wood I bought was seasoned), I wouldn't buy a MM if I had to do it over again. Time c/s/s is a much better indicator than a digital meter.
I have a harbor freight model and it is decent though I don't use it much. I changed the batteries to Duracell if I remember right and that did read quite a bit different than the chepos it came with. It got tested next to my buddies $80 moisture meter and it was within 2% difference after the battery swap before it was around a 6% difference. Not bad for 12 bucks.
In appreciation of your past or present service, I'd be willing to send you mine free of charge (I'll have to look tonight for the brand), I have no use for it.
Using a General MM1E that I picked up at a local country hardware store.
It proves that my seasoned splits are dry and all else needs to stay in the shed.
While not quite a MIL spec tool, it gets the job done and for a fair price.
My harbor freight one has always agreed with my thoughts on how wet the wood should be, so very happy with it but I do not use it that often just for fun.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
