Wehrleyfamilypoultry
Yes I. Checked the OAK. That was the first thing I checked. It checked out clean.
There are NO dumb questions. Only the ones that I ask my wife. She's sitting right here so it's ok!Sorry this may sound dumb
What are all these adjustments for? I mean what do they control? We've had this stove for 3 years. I knew there was some hidden controls but didn't realize there was that many.
Hey @mustangwagz, good to see ya around and warm! Ya it's going to continue to be cold. Not looking forward to the snow starting here tomorrow, up to 12", who knows! I actually have one clinker pot left that I had saved because I wasn't sure how they would stand up. I'm on my 9th or 10th year now and mine looks like it did after the first burn. I'll pm you about the pot as that is the only one I have and can't make any more.Auger aND panel seem good. I was just getting to much corn for the flame to burn it. I put the low feed end on 1.5 and raised the low end air. I'll see what happens. Df, and Aux are both on auto
You got me on that one, I see nothing in the manual about it, but if you are pushing the mode button and the auger delay and nothing pops up on the board then maybe you are just putting the stove into manual or auto because that's what the mode button does.When I first got this stove I was told to push mode and auger delay at the same time. What does that control?
Press and hold them too. The screen will pop up. You can select the heat range setting then hit ON, then a number pops up and you CAn change it.
It's extra setting for corn . It also does it in pellet mode.
Hey, if it's filling up then you will have to either bump up the highest DF setting or lower the highest HR (feedrate) setting.Stove is burning better. I lowered the low end pph to 1.5. I haven't messed with the air yet. After about 6 hours on HR 4. The burn pot becomes full. This is much better considerin I could only burn and hour before you guys helped me. Im burning on HR 4. My Dr is on 5, Aux is on 6. Could I mess with the low and high ends? Or just adjust the df?
I've been out clearing snow this A.M. and will be again later so I'll chime in when I can.Ok. I'm running df, and Aux on auto. I raised the high df.
As it stands right now.
Df low 220
Df high 290
HR low 1.25
HR high 3.5
Like I said, it is running better. Just not grear yet
