Dishwasher troubles...
mwhitnee
586
Central Mass, USA
I have a Kitchenaid dishwasher that the bottom half works, but no water pressure is going up the tube to the upper rack to clean the dishes on the upper rack. Annoying, I just fixed the upper rack the other day.
Has anyone encountered this before? Here is the pump diagram.... Kitchenaid Model KUDS301XBL1
http://www.partselect.com/ModelSect...sition=9&mfg=Whirlpool&Type=Dishwasher&Mark=9
Thought it might be a pump but I think it has only one. Check valve?
I took the upper rack off and am only using the bottom...
If I'm remembering correctly there is an impeller under the lower spray arm that sends water to the upper spray arm. The gray 90° piece in the back should have a valve in it also.
The impeller is usually the culprit though, I think we've replaced 3 on my parents.
Reactions: mwhitnee
For flow problems on dishwashers...start simple. It could be a clog. If everything sounds normal, (as in..pumps are starting and moving water) i'd start pulling off the horrible plastic parts and looking in. Or, if you have an air compressor, blow some air down below and see if it comes out the top...with some old steak behind it.
Reactions: mwhitnee
We're on a non chlorinated water source so I have been pretty grossed out with the goopy shmooky looking stuff that can grow in the dishwasher. It grows fast too and can get away from you if you let it and start clogging things up. Every couple of months I add a 1/4 cup of bleach to two stages of the load to the clean and kill the growth which turns white and blows out. You've got to listen closely, these modern dishwashers are quiet but also run over 5 stages of filling and pumping out per load. They take like 90 minutes too!
Reactions: mwhitnee
It was the grinder wheel assembly. Took 15 minutes. It was a $17 part.
There were seeds and things under the cover that houses it. The grinder was kinda blown apart and wasn't turning. Took out what I could by hand, shop vac, installed new grinder wheel. Top is now getting water. 5 Torx screws.
Think I'll do a empty load with bleach, get one more seal for the upper water tube, which is easy to replace, and call it a day. I imagine with the upper rack repair and the wheel I saved myself around $300.
Don't use too much bleach as the rubber seals may not like an overly strong solution. Most important is the dang dishwasher fills and empties itself like 5 times during the full cleaning cycle. So this means that you want to either load bleach five times or make sure that you choose one of the long stages so that the bleach is circulated as much and as long as possible. You want the last stage to be without bleach so that the bleach is purged out of the dishwasher guts at the end. The first fill/empty stage is like 10 seconds of running just to blow the big chunks off of the dishes! So for sure skip the first and last stages.
Reactions: mwhitnee
If you're concerned about it, get some pool shock and put a quarter teaspoon in the dispenser. Most are around 50% cal-hypo and it'll get dispensed at the correct cycle and rinsed properly without any fuss.
I always wondered how a strong does of chlorine would do with the dishwasher detergent.
I already add a 1/2 teaspoon of TSP to the soap dispenser to get back those lovely phosphates.
For an every day use I would cut it down to 1/16 tsp maybe less, 1 tsp in 15 gallons of water will give it 20 ppm of free chlorine.
Any concerns about the interaction of granular chlorine with the dishsoap? The pH will be changed, the chlorine may neutralize the soap or the soap may neutralize the chlorine.
Shouldn't be any issue assuming there isn't any peroxide in the soap. You could probably make your own blend using, cal hypo, tsp and borax if you really wanted to.
Hmmm, I already am adding the TSP and could easily mix in some sodium dichlor granules that I have on hand.
