I saw a guy on YouTube do one kind of like that. He called it a "HolzTwinkie" as it kind of had that shape. Long pile with rounded edges. Here's one video but I've seen others with the pile completed.I think my next stack I will modify into an oval shape so it will contain more wood in a smaller footprint. Anyone try that instead of the usual circle?
Productivity does seem to drop once you get over your head when stacking, but for retreiving wood from the top is where the hookeroon comes in real handyEven though you can go higher with the holtz, productivity must decrease since you have to lift and place the splits over your head; also when removing.
here's a small one that I have posted before..... right now i have piles, stacks, rows, quick stacks, 2x4/cinderblock stacks.... i need to get a better pick of what I have...
View attachment 197935 View attachment 197936
That is a little costly--I'd have a grand or two tied up in covering the wood. I do cut a tarp in a circle for the bottom. Helps me stay true to the circle and also acts as a barrier to mushroom mycelium coming up from the ground into the wood.A buddy of mine sent me a video with this in it since I mentioned I need to build a wood shed. Kinda cool especially since the base and top connect so you hopefully don't lose a cover just a little steep on price and I would need probably two for each year of wood supply as I think the max it would hold about 2.2 cords per the diagram so it would get expensive to have enough for 3 or more years ahead.
https://www.amazon.com/dp/B01LY6118S/?tag=hearthamazon-20
I've been contemplating building a holz since I have limited space to store and dry wood and that I wouldn't really need to move it again once stacked.
Lopi Rockport
Lopi Rockport
I see you're in Arlington, WA. I'm in Glacier. I think it's a bit wet around here for a Holzhousen to work very well. It would definitely increase curing time over methods more traditional in this area. I noticed there is no drip edge so all water from the "roof" will run down (and inside) the stack potentially creating mold/fungus. It would work if it had a gutter system to channel the rain water away from the stack and you had two years to let it season (three for slow drying species). I would also like to see small eaves to protect a bit from winter rains which often fall at a 10-20 degree angle from vertical due to normal winds. Otherwise the humidity inside the stack further slows the seasoning process.
I've had good success with this system:
Wind driven rain can still wet the wood but it will dry quickly and there is no big cover to hold humidity in. Water drains off the ends due to the corrugations.
yeah they look cool but seems to me they would take more effort to build and i'd rather cut down on my labor & time rather that increase it.
I've been some videos from this dude out west, he seems pretty legit, anyway, in this video he actually has a holtz cover that wraps from underneath to the top, keeping the sides open for air. very interesting and I wish I figured this out.
