The firewood I have is 18-20" need 14-16 for new stove. Is there a ez way to cut shorter? The wood was cut for my old home which had a wood furnace and could take large pieces.
Move that post count up.The firewood I have is 18-20" need 14-16 for new stove. Is there a ez way to cut shorter? The wood was cut for my old home which had a wood furnace and could take large pieces.
-1 on the sawbuck. Seems like too much work even before the time and expense of making the thing. Cutting a huge pile then dealing with/stacking lots of "right sized wood" and cut offs...ugh! Use a miter saw on the 5 logs for each fire and burn the "right sized" and short pieces immediately. I'd rather spend an extra minute cutting the five logs for every fire than spending hours doing the whole pile at once.+1 on the sawbuck.
Search: H-FRAME SAWBUCK
Instead of the typical "X" shaped sawbuck, I like the H-frame design for cutting the ends of many logs at a time. You can build a dedicated sawbuck, but the gentleman pictured below simply put a couple eye bolts for anchoring a ratchet strap or bungee cord on an existing log rack. I saved a couple of his pictures years ago because I liked the idea so much.
What blade do you use? Every one I've tried in the sawzall was very slow and laborious.I don't have a chain/miter saw, end up using sawzall, works fairly well
I agree with the sentiment of: Just get it done in whatever way seems the least painful to you. I've done cords and cords, I prefer the 12" chop saw for straight pieces, for big and uneven chunks, I bungee them in the sawbuck and use the electric chainsaw. Not fun when I get too aggressive with the chopsaw, and so monotonous. But, better the alternative!The firewood I have is 18-20" need 14-16 for new stove. Is there a ez way to cut shorter? The wood was cut for my old home which had a wood furnace and could take large pieces.
How about an ad on Craigslist to see if someone will trade you shorter for longer. You lose a little wood but save quite a bit of effort. I am quite often surprised at what I can accomplish though Craigslist.The firewood I have is 18-20" need 14-16 for new stove. Is there a ez way to cut shorter? The wood was cut for my old home which had a wood furnace and could take large pieces.
+1 on the sawbuck.
Real nice, Ash. I think there is a powerful metaphor for life in this.Here’s the Ashful wood-shortening apparatus rev.a undergoing initial testing. I built this when I installed my Ashfords in 2015, and built a bigger better rev.b in 2016. They only take an hour (or less) to knock together, and it allows me to cut about 1/6th of a cord from Jotul 600 down to Ashford 30 length, in a single pass of my big saw.
Note those chunks on the ground... I have a love/hate relationship, with those thousands of chunks it generates.
What a great idea. Simple and elegant.Ashful, I was just going to suggest what you have built. I can take a picture of mine, but picture this: Build this frame or raise yours up 14" or so. That way you can slide a box, tote, or milk crate next to it to catch the "heat chunks". Saves one more step.
Your nut cleaner is awesome. Love it!I have a rig for that, too, Ed!
Think driving range golf ball picker, and you have the idea on how they work. One in front to get right around structures and trees, one behind for the rest. Might move the trailing one to belly mower location, someday.
On the wood shortening rig, catching the offcuts in the tub would eliminate that chance of separating them from the pounds of saw chips this process generates, although I guess we could find a way to manage that, too. Do not under-estimate how much chip you’ll generate when cutting down a full cord or two at a time!
This is my favorite sentence ever posted on this forum. Period.Your nut cleaner is awesome.
