If someone gave you a new or better part for your pellet stove, what would you get?
Don2222
9,117
Salem NH
Hello
I would put in the new auger motor with needle bearings! Like a car wheel bearing with all the little rollers, that is what needle bearings are!
Auger motors have sleeve bushings, and the better ball bearings but I have a friend with a Fahrenheit Furnace and the auger has an over hung load or a cantaliever effect which made a ball bearing auger motor leak grease around the shaft after only 1 month of use!! So he put the new needle bearing auger motor in and it has been working good all this season!
So what do you want in your stove?
Reactions: Stovensen and Ssyko
I would like an new control board for my 25pdvc. I fix one thing and now i'm chasing another. the lil gremlins need to leave my control board and find a new home.
Hope you have the stove plugged into a really good surge protector?
Its one i picked up pre damaged.
Hello Don,
Anything that makes it easier to deep clean the stove is on my wishing list.
First: I wish it was easier to "get under the hood".
Example on the picture:
If you need to adjust or service these Mercury outboard engines, all you need to do to get inside is to turn the black knob 90 degrees, pull off the front cover, loosen two stainless handles and the engine cover can be removed. It takes 10 seconds, but the cover is still perfectly tight against sea water when mounted.
Note how harmonic the overall design is. A beauty to the eye.
Reactions: FirepotPete
Hello Don,
If you are in a Damp Climate then the Selkirk Direct Temp Venting makes the ash drier and the stove easier to deep clean. :)
Sounds interesting. Do you have a link so I can study the details?
And another thing. My blowers work perfectly, but next year they will be 20 years, so you never know... Is it possible to get 230 Volt versions for a Quest Plus in your webshop?
I'm amazed of the bearing quality of these original blowers. They show absolutely no signs of wear, when inspected during the cleaning. I have always lubed them with the right oil.
Reactions: Don2222
Well since they're giving it to me, I'd like a fully programmable controller. Where I can adjust all the settings or program them to adjust on their own, and connect it to an on/off thermostat if I wish.
Other odds and ends, like easier access to the cleanout doors, could use improving, but I can do that on my own for free.
Here is the link
http://selkirkcorp.com/sitecore/con...kirk/products/direct-vent/dtm-biofuel-venting
I installed this on a customers Whitfield Quest in Manchester NH and it works super!
Hi
I just bought an Ashley Bay Front with the new controller with the remote control. Is this the controller you have?
I have to learn more about it but it looks better than the old controller with the 5 LED heat levels.
Pic 1 - old controller on 5660
Pic 2 - New Ashley AP5660L Bay Front with legs
Pic 3 - New controller and remote control
This is a standard installation option around here.
But I had not realized the advantage Don cites.
Not wishing to re-open the polemic < to OAK or not to OAK> , this surely this is a plus for the 'No OAK'.
I'm obviously talking about a simple 'straight from outside' OAK here.
Why easier to clean ?
I want a SELF CLEANING stove.
Hi
Your 2nd and 3rd pics are the exact controller I have. It was used in like 3 or 4 different stoves.
