I am torn between a Skidsteer and a tractor....would love to have both...but can't afford both.Either way it would be hauled to logged out woods and used to load my dump trailer and trucks up...the tractor appeals to me for many reasons....its more stable...I can drag with it...ect...just not as fast or nimble but very bit as capable...decisions...lolView attachment 220717 Tar12 my tractor with front end loaded I believe is around 4000 lbs. I have never hauled my tractor anywhere yet but I have two 3/4 ton diesel pickups to haul it with when I do. The other questions you asked I don't have the answer for without looking at mahindra's specs for the tractor. It does everything I have asked it to do with little problem. I think the loader can lift over a ton but not positive. I have loaded the grapple up with heavy rounds and it hauls it no problem. If the tires were filled I'm sure you could push it to lift more, I just have a heavy box scraper or in this pic a 6 foot finish mower for weight and that works fine.
Is your grapple bucket from Mahindra?Sodbuster that is black locust, a buddy I work with his father has a large locust grove near his farm that he keeps having large trees removed. Neither one of them want the wood so I make out. I agree with jwfirebird unless on a construction site I think a tractor has many more benefit. Implements are not as expensive easier on the terrain. Much easier to work on. Just my thoughts.
Will do @heavy hammer , the frost hasn't left yet so we need some rain with warmer weather so I can start digging out some stumps. I can push a screwdriver in the ground about an inch before you hit frost.Looks like fun, I have about 5 ash trees to take down, but as u said this cold wet weather needs to go. This winter was rough to get any tractor projects done. It never really froze here enough to not trash the yard with the tractor so I have been waiting for spring. Keep updates on the garage.
