So the stove has 5 heat levels, 1-5, 5 being the hottest. It consumes the most pellets and has increased air flow in the combustion chamber and the convection blower fan. So as you learn the heat levels of the stove and how they relate to the weather outside you will set the heat level you need, so you set it accordingly. If it's really cold then you let it rip at 5 level (though level 5 is really hot, especially for that stove, and I think you will rarely use it).
But start at level 3.
Then the stove has 3 operation settings:
Manual just runs the stove at whatever heat level you have it at.
Auto/off runs with the thermostat connected, so when the room drops to a set temperature, the thermostat calls for heat and the stove turns on. Once it reaches the required temperature, it shuts off. This setting is mostly used in the fall and spring, because you mostly don't need the stove to run during the day on mild days, but do need heat on cold nights.
High/low also uses the thermostat, but it always keeps the stove on. When the thermostat calls for heat, the stove runs at the heat level you set it to (1-5), and when it reaches the desired temp, it turns the heat down to a low, idle flame (level 1). This is where you save pellets, in the idle mode.
Here is the owner manual link, pages 8 to 9.
https://enviro.com/custom_content/docs/manuals/C-14596 Instruction Maxx-1 Domestic Owners Manual.pdf
And the more technical manual, page 8 for the thermostat info. Look for a 12 volt remote thermostat.
https://enviro.com/custom_content/d...truction Maxx-1 Domestic Technical Manual.pdf
