QuadraFire Castile Insert Auger Motor Noise
skives19
58
Michigan
I have read many threads on here about auger motor noise but my QuadraFire Castile insert auger motor is making a noise that sounds like buzzing. The auger motor was new from January 2017. I just removed the auger assembly two weeks ago and cleaned out the feed chute. When I did that the auger wasn't making any noise for two weeks now.
As I type this I have two things coming to my head. One is the auger slipping and not tightened enough (the set screw) or cause I have the feed rate at its lowest level is the auger hitting that plate?
Any help would be appreciated
The two things you mention are possible, and cleaning the auger tube could have cleared some fuel that had gotten past drop chute and was starting to bind motor. Hard to diagnose a noise over the internet. kap
Reactions: Mt Bob
Here’s a video of the auger and noise. Hope this helps.
  • 3FD2CDDC-704B-4757-A3FB-5D9B6BB08C5C.MOV
That's a noise I never heard before. And even hearing it, it is still hard to figure out what it is. If the auger wasn't tight to shaft, you would not have a good fire, if it was slipping. You could tell if it was hitting the bottom of hopper, by looking and seeing if there was any scratches. Still sounds like a motor noise to me. And you say it quit after you pulled auger assy.? kap
It did happen again after I pulled the assy but I thought it might be coming in contact witht the feed rate lever so I opened it some and it stopped. That was two weeks ago and it come back last night. I just now tried to feel around back that while it was running and now it has stopped.
Two things. you can definitely tell it's the auger making the noise cause I see the auger motor move and that's when the sound happens. Second it seems to only happen when the stove hopper is low on pellets.
Is it typical for these auger motors to not last long?
I have seen some pretty poor quality in parts the last year or two. Lots of new thermocouples that don't work. Quality control must be on vacation. Strange that it does it when hopper is low, compared to any time. Still sounds more motor then anything else. kap
They are a sealed unit, but I know of some that have carefully taken them apart and oiled them. I know of one guy that put a little 3in1 on the small shaft that sticks out of the end of the motor(topside where strap clip is) and it quit making noise. kap
If it does yes, but it may only do it under a load too, as pellets in the tube
Noticed two things overnight. One I filled up the hopper pretty full before going to bed and the auger made the noise. Two the stove shut off at around 12:30am cause it hit the temp on the thermostat, then came back on at about 1:10am and no noise. Could the auger noise be from running fr long times on high heat?
I have read in other places to empty the hopper of pellets then take a couple handfuls of pellets and mix them with some graphite powder and run them through the stove. Is this safe to try?
Usually the pellets themselves clean the tube
Did you bench test it yet? Or oil the end of shaft?
No I cleaned the stove completely and that seemed to help. Didn’t notice anything though that would of caused it. Let’s hope it stays silent. I have a feeling though the noise will come back and I’ll be shelling out money for a new motor. The 90 day warranty is to short.
I agree on the warranty.
One thought am I missing some part of the stove to clean. Yesterday I took the combustion blower motor off and cleaned that along with the auger assembly and feed chute and the baffle and brick inside the stove.
My auger started making noise for intermittently and I figured it was on its way out. I didn't want to screw around so I planned on buying a new auger motor that weekend and sure enough, the motor quit on me that week. Installed a new one and was up and running.
Reactions: kappel15
Yeah I have one on the way Monday but this current one is only 11 months old so I don’t understand why it would be going already.
