Stove Reviews
Hearth.com Wood Stove and Fireplace Review Section - thousands of ratings and reviews on wood, pellet and gas stoves and fireplaces
Review of QuadraFire --- 3100 millenium -- Freestanding Stove burning Wood only
Installation Type: Wood/Coal - Freestanding into metal Chimney
Date Reviewed: 2006-11-30 21:52:02
Satisfaction Ratings from 5 stars (best) to 1 star (worst)
Satisfaction with unit = ✰✰✰✰✰
Satisfaction with dealer = ✰✰✰✰✰
Satisfaction with manufacturer = ✰✰✰✰
Other Information about the Home and Stove
Room Size (Sq ft): 400 | House Size (Sq feet): 900
Bought in 2006 , Price Paid: $1,300
Purchased from: Fireplace Retail Store - Sebastapol, Ca.
Likes: This stove is easy to start and burns wonderfully. Doesn'nt use up as much wood as my 25 year, older vermont casting stove did.The neighbors enjoy the reduced smoke level also.
Dislikes: The fire box is a little small so you have to watch your log size,also the baffle tubes on top limit the height you can install wood up to.This a covection stove so it takes a little longer to heat up the room then my old stove.The glass does get a little dirty with each burn but since it's my first season maybe I'm burning at too low a rate and it's not the air washes fault.
Comments: I installed this stove to exact manufacturers specs, this makes a big difference with any stove you choose, so follow the manual.Choose your dealer and installer carefully so you won't have problems later.All the work in my research paid off and I'm comfortable to recommend this model you'll be too.
* Dates that reviews were submitted were not recorded prior to Nov. 2004
