Been basically flawless.  Runs anything I put in it, cheap pellets good pellets don't matter.  Loves corn (and so do I).  I typically mix 3 parts corn to 1 part pellets (keeps the corn clinkers under control.
Replacement parts have been very few. Couple agitator rods and a couple door gaskets and one distribution blower and that is it but then it gets serviced regularly and every spring, the gearboxes get greased and motor bearings get oiled and the combustion fan comes out and cleaned as well as all the venting gets taken apart and washed inside.
I did have to replace the view glass once, my fault, I closed the door too abruptly and cracked it.
I will have to replace the venting sometime this next summer, the nitric from the corn has eroded the stainless liner in the venting to the point where it's getting pin holes in it.
Other than that, no issues at all.
I do fog the inside of the stove every spring when I mothball it for warm weather with Stabil fogging oil and toss in a large desiccant pack to keep the moisture under control.
Been a good (and cheap) 20 years and I expect it will last until I'm gone with proper maintenance.
