I just moved into a new home and my first experience with pellet stoves has been riddled with unknown problems. I watched the video that the previous owner left behind and have read the manual from the website. Since I have never used this type of heating before, I am at a loss for troubleshooting and the number to Englander is always busy. It seems to do a very good job heating the home and the tiny amount of ash is very welcomed as opposed to my experience with wood burning fireplace inserts.
We have a 25-PDVC pellet stove unit. We can start and run the unit almost 100% of the time as long as we use the Heat 1-2 and Fan 9 setting. If a higher temp is desired, the stove shuts down with a E1 code usually within an hour. At first I thought it might be overheating but I found that I would get an E3 error code which I never have.
After the unit shuts down, attempting to turn it back on results in first an E0 then a display of the current settings, an E2 error, then an E1 error. Usually after this if we wait for 20 minutes, the stove will start back up without issue and continue to run if the heat settings are moved back down to 1 or 2. This may be normal but the glass soots up within a day or 2 of cleaning.
The auto-igniter does not appear to be operational and I found a bottle of gel lighter next to the unit on move in day. I do not have issue with manual lighting it and only mention it as it may help lead to troubleshooting the problem. Also, I cannot distinguish an increase in air flow if I move the fan speed from 1 to 9 but this may be due to my lack of familiarity with a pellet stove.
I have disassembled the flue and cleaned out the inside and outside portions along with the burn pot areas and behind the plate. I also vacuumed the hopper gasket to clear any debris to make a better seal. I was sure that I had solved the problem when upon removing the flue I found that 80% of the portion of the flue that was horizontal with the stove was filled with ash. This did not seem to be the problem though as it continues to shutdown on any heat setting now other than 1.
I'm not opposed to replacing parts but, would appreciate any help pinpointing the exact faulty item. I appreciate any insights provided to a newbie pellet stove owner.
