Hi again, looking for input on where to place the 3-way valve for return temp control and the circulating pump for the wood boiler. See image.
http://i103.photobucket.com/albums/m132/mjenphil/WoodBoiler/Pump-location.jpg
To me it would make sense to place the pump between the wood boiler and the 3-way mix port so its drawing both hot and cold return water through equally. WHere as in the setup on the right it would be pushing cold water into the valve and possibly not allowing the valve to work properly and inject the needed hot water? Your input is much appreciated.
~ Phil
~ Phil
