49-TRCPM Dry Run
nhredbird
105
Southern, NH
Did the dry run, 1-1 in led windows turned to 5-U.
Combustion fan came on, Stirer turned in pot, Glow plug igniter turned red hot, Checked the auger was tuning by opening hopper.
20 min. later E-2 code came on at panel.
Could here the air pump.
Then it shut off and i un-pluged from wall.
Am I good to continue?
Still haven't heard room air blower?
Its raining here, maybe put back outside on sunday and 1st fire with pellets to do the seasoning burn on 5-5 for couple hrs.
seems to me room blower wont kick on until youre burning pellets and reach required temp.
Load that puppy and go.
Stoves will run from 5-10 minutes before the convection blower (room air) kicks on. Takes awhile. Bit the stove has snap discs that need to reach a certain temp before the blower comes on.
The figure you saw in the control panel after the 1-1 was actually "S U", which means "Start-Up". When you "Shut Down", you will see "S D".
You are ready to burn. Load pellets and go....the room air blower won't come on until the control board heat sensor sees about 120 degrees constantly.
