emt1581 said:
We had the installer over the house last night and he said we CAN do a direct connect from the back of the stove to the wall, but that he recommended coming up 2' from the stove and then elbowing it into the wall. He said it would increase the draft. I'm curious if it matters THAT much and if it was good advice?
Ideally, we'd like to direct connect so you don't see any pipe.
Thanks!
-Emt1581
Hi EMT,
It's an interesting question, and here's my understanding, submitted for consideration.
As I understand it, draft is produced by a temperature difference (like between a stove's outlet and outside air) across a given rise (not distance) of pipe--your overall chimney height.
Clearly the overall rise is the same regardless of where the elbow is, so when everything is hot, elbow location makes little difference in overall draft.
The performance difference comes when lighting a fire.
Before you add flame, the flue has an initial amount of draft, produced by the difference between temperatures inside and outside your house. When you start the fire, the first chimney section it heats--and the first to potentially add draft--is the section closest to your stove. If that section is vertical, the height and temperature difference across the section nearest your stove produce additional draft, and your fire take off right away. If that section is horizontal, there is no extra
heated height to product draft, and draft will not pick up until the area *after* the horizontal section heats up. This slows startup, and can cause smoke leakage and make lighting a fire more challenging.
So IMO your installer knows of what he speaks.
That's my understanding anyway, for discussion and correction.
I HTH, and good luck!
