I have a breckwell big e had it about a month when running on 1 it has went completley out three times other than this the stove has been trouble free any suggestions?
StoveMiser said:Switch the trim to 1-4 the highest trim setting and you should be fine. I look at setting 1 as like a pilot and nothing more. In my opinion its not even worth running the stove on 1 because of the lack of heat output. I consider #2 low.
StoveMiser said:To avoid pellets missing the burn pot, you must make sure the pot is pushed back all the way so there is a very small gap between the firewall and burn pot shroud. Every time I scrape the pot it moves away from the firewall just enough that pellets can catch the lip and miss. Get in the habit of pushing it back each time you scrape. No biggie, one push with your scrape tool should snug it into place.
rove44 said:How often should i scrape the burn pot? what exactly am i scraping?
rove44 said:Does it need to be stirred while it is still going??
