Friday the stove was running fine, but around noon I noticed the temp was dropping. I kicked up the thermostat, the combustion blower started but no pellets dropped. I tried again with the same result. The combustion blower started and I could see the ignitor was working. I took out all the pellets and cleaned the feed tube, there were no obstruction, i reset the snap switch, put in some pellets and tried to start it again. same thing combustion blower starts, ignitors is working but no pellets. Yes, i had enough in there to start the stove. So, I went to a local dealer and spoke with him, he mentioned the number 2 snap disc and resetting it and how to bench test the auger motor. I bought a new switch. I installed the new snap switch still the same. I bench tested the auger motor and it worked with another source of electricity. I then called the dealer I bought the stove from and he explained how to by-pass the hopper switch and the vacuum switch. I tried to start the stove and it worked. I let it cycle and cool down so that I could try again. I let two hours go by and tried again and the feed did not work, again. I talked to dealer number two again and he said it could only be the thermocouple. Which I regrettably bought, installed and it as not the problem. I am totally dumbfounded.
I should mention this is a new control unit that was installed four weeks ago and the stove was running daily until Friday.
Also, if I do a start up and hand feed pellets, they will ignite but no will drop. I can hand feed until the convection fan comes and it shuts down like normal
