Carolina wood stove
Old man
5
United States
[Hearth.com] Carolina wood stove
Can someone please help me identify the model of this stove
Also ... I'm going through wall and up side of house with flue. Should I stick with 8" same as outlet size?
it looks like a buck stove to me but there were many copies out there also. And yes if the outlet is 8" the chimney should be 8" to
Thanks. I finally got the id plate clean enough to slightly make out the brand and model. Can't make out clearance specs or nothing else. It's a Bat Cave Carolina 1
ok so it is a buck copy. I can tell you the clearances are probably 36" to combustibles
Ok thanks. Started clean up and inspection today, the old boy is looking pretty good. Have one question so far. The fire brick on bottom of fire box has space between them and walls should i seal around them? Its maybe 1/4 " gap
You mean there is a gap inside between the firebick and the side walls? If so then no that will fill with ash and not be a problem.
