I have a Castle Serenity pellet stove. I have a hard time getting it going, but once it is going it runs fine.
The igniter isn't working so I've been lighting it with some starter gel and a burn pot full of pellets.
I think there is too much air going through the pellets during its start up process. When the start up fails, it seems like it is due to the pellet feed rate being inadequate to keep up with the burn rate.
I have about 5' of 3" PelletVent going into an existing 6" chimney that was previously used for a wood stove. My guess is that there is inadequate back pressure to keep the air flow rate low enough.
I've lowered the exhaust voltage for Stall 1 as low as it will go (I assume this is what is used during the start sequence, but I don't know for sure) and this hasn't helped. I seem to have the best results when I run a space heater on the same circuit as the stove when it is starting up - I can audibly hear the blower slow down when the space heater is on.
Any suggestions for how I might might the start up more reliable?
