Champion 3500W/4000 Port. Gen.
Beetle-Kill
1,849
Colorado- near the Divide
Had a number of positive posts from a previous thread, just wanted to get some input in general.
I don't suffer from frequent power outages, so it won't be used a lot. Primary usage at the house would be to power the blower on the stove, fridge, and a few lamps. Off-site would be grinders and a 110 MIG, maybe some other stuff not exceeding 15A.
Can the 240V plug be converted or a pig-tail added to give multiple 120's?
Durability of this generator?
My price range is in the $300 area.
Thanks in advance, JB
You could split the 2 legs on the 240v line, but I'd imagine the gen set has 120v outlets? Just plug in a power strip if you don't have enough outlets.
Reactions: Beetle-Kill
One of the threads was mine: https://www.hearth.com/talk/threads...ion-3500-watt-generator-30-coupon-code.64555/
Mine only came with 120v outlets. There are extension cords that you can buy that do essentially the same thing you're talking about.
I haven't used mine except to test it a couple of times, but as I said in the thread, everything seemed to run smooth except that the washer control panel started blinking and beeping.
I'm almost tempted to sell it 'cause I got a Honda eu2000i for the low power stuff. Maybe I could get a good price for it in a couple of days :) , but then again, you can never have enough generators, right BrotherBart?
Some generators don't have the 120V output balanced on both windings of a 240V genset. So you would have to split the 240V to use the full capacity @ 120V.
In this case, it appears that this particular unit is a single winding 120V generator that does not output 120V. So getting the full output would be tricky since you're most likely limited to a 15 amp limit via a power strip plugged into a typical receptacle. (I've not seen a 20AMP strip readily available)
3500 watts / 120V = 29.16 Amps (we'll say 30 ;) )
You would need a 30 amp 120V plug/cord that somehow splits the output to devices with their own breakers (powerstirps?) to really get the full output from this unit. You mentioned that you don't intend to use much more than 15 amps at a time so maybe this isn't even an issue for you.
http://www.tractorsupply.com/gas-di...eZip=12566&ddkey=http:LocationBasedPricingCmd
This is the unit we're talking about right?
[Hearth.com] Champion 3500W/4000 Port. Gen.
That's it, except the left receptacle has a 120/240V 4 prong set up.
Velvetfoot, thanks for posting that link, I must have missed that thread.
Looks like a good little unit, hopefully I'll only use it when I want to, not need to.
Then it should have two banks of 120V receptacles. You'll have to balance heavy loads across both windings to get the full potential of the unit.
There are several versions of this genset available. Mine is the more common verions with the 30 amp 120 volt outlet as well as a twistlock 30 amp outlet for 220 and a single duplex wall outlet looking thing. There is a switch where you select 120 or 240 volt output. That makes this a 120/240 genset.
Here's the deal. If you use the 220 twistlock and split it you will only get 15 amps on each leg plus you will imbalance the legs and have voltage regulation issues. The 120 volt 30 amp outlet on this genset gets all 30 amps which is super cool. Bottom line is you are better off splitting the 30 amp 120 volt outlet into a bunch of 20 amp plug sockets than you are splitting the 220 volt twistlock.
I have the 40026. It is totally 120V. Best of all worlds for me.
  • [Hearth.com] Champion 3500W/4000 Port. Gen.
I am all good with the 120/30amp. set-up. If I only have to run one big cable inside, and have it branch from there, that's a win-win for me.
I have had good luck with mine. I have this one http://www.tractorsupply.com/champion-power-equipment-trade-3500w-4000w-portable-generator-4434023
It has the switch so you can either use the 120 side or the 240 side, but not both at once. There is a good cord setup that I got from HD
for it...its here: (broken link removed to http://www.homedepot.com/Outdoors-Outdoor-Power-Equipment-Generators-Generator-Accessories/h_d1/N-5yc1vZbxbm/R-100675653/h_d2/ProductDisplay?catalogId=10053&langId=-1&storeId=10051) I notice its out of stock but should give you an idea of what to look for in a cord and multi plug setup. You could build one yourself as well....
Look around their website to get the specs on them... http://www.championpowerequipment.com/products/generators/
Only thing I didnt like on it was the handle to move it around with isnt very well made...just bolts on with friction and wont stay put very well. Runs and starts great for the now....cant say how it will be in a few years thou. I did buy the wheel and handle kit seperate, but I only did that to make it easier to move around.
Some good vids out on Youtube of them....
I didn't buy a wheel kit but just set it on a mover's dolly to wheel it around the garage and out onto the driveway.
