I have a 5500W generator on hand that I can manually plug in through my garage and power my entire breaker in the event of a power outage, I can ready it within a few minutes. My concern is what happens if my pellet furnace is running and the power cuts out, I need something to run that stove for a few minutes (just the fan/blowers) while I ready my Generator, or begin a shut-down routine, in that case the flame usually is out within 10 minutes although the exhaust fan stays on for a longer time to ensure all exhaust has been vented. Pending that the UPS supplies enough power (the one I'm looking at supplies 810W, WAY more wattage than my pellet furnace draws even when running full blast), and can run the blowers for 15-20 minutes (we never run the pellet burner when we're not home), would there be any harm in going with a typical higher wattage/high VA 120V UPS designed to run electronics during a power failure?
http://www.amazon.com/CyberPower-CP...FI/ref=sr_1_13?ie=UTF8&qid=1294070940&sr=8-13
I've read through a few threads where others have described wiring up massive amounts of battery power, but I don't need a lot of Amp hours just to power down my furnace or switch to Generator power. At any rate, just wanted to find out if there were major issues running a typical PC UPS to power a Pellet burner for a few minutes. Thanks.
