Corn Stove Basics?
LRRifleman
58
southern New Jersey
Hello,
This is a dumb question, but I need to ask. FOr long time, I have wanted to get a small farm and grow corn (among soe other items), and use the corn to fuel a corn stove for my home. Sadly, tese plans have beentemporarily deayed, but I still am planning. When I bought a wood pellet stove for my home, the dealer seemed to be very discouraging about corn stoves, claiming they needed a high degree of maintenance and frequent cleaning because of the residual sugar from burning corn. Is this true?
Thank you for your advice!
Corn stove will indeed need more attention as far as cleaning and maintnence, but I guess that depends what stove you have. I have seen some really nice multi-fuel stove that dont need that much attention. Enviro has the M55 and the Maxx-M which has a very nice burn pot agitator design.
Many pellet stoves will burn a 50/50 pellet/corn mixture, and will do so pretty easliy, but if you want to burn 100% corn, either a dedicated corn stove, or at the very least a multi-fueler as mentioned above should be considered.
Also, don't forget that you need an exhaust system that is corn-rated.....a little more $$.
In addition to the models mentioned above, I have an Englander 10-cpm multi-fuel unit that burns corn very nicely. Another model that will burn corn easily is the Bixby. It is somewhat unique in that it has built-in cutter that cuts off the "biscuit" that forms from the corn after burning.
Here's a video showing the Bixby:
www.youtube.com/watch?v=arUEQ1q4sIk
Also, this website is a forum specifically for corn burners....a LOT of good info there:
http://forum.iburncorn.com/index.php
I have two stoves in our showroom that I burned coal in full time. A little more cleaning, but thats it. Get the right stove, plant enough corn to give ya 4 or 5 tons a year, dry it down to 12% or so and your one step futher from the grid.
One of the stoves we have works off a 12 volt system, so a little solar panel hooked to a battery bank would run it.
That, some livestock and a garden and your all set!
