Ok..so I am having an odd problem with my Englander 25pdv pellet stove. The fire in the stove is always small and never puts out much heat. Specifically, the stove lights and the fire will keep burning but just barely. If I set the stove to 7 or 8 the fire gets larger but it just isn't putting out much heat {almost none}
The combustion motor and the room blowers both seem to working just fine and the stove is not smoking. It is almost like the stove is having a problem on the upper auger. The lower auger appears to be rotating without any problems.
I am going to tear the stove apart this weekend and give it a good cleaning {including leaf blower method} I will also doublecheck the auger motors, but since the fire does start and keep burning I don't know if this is the problem.
Any suggestions on what to check would be appreciated
Thanks.
