Enviro M55 High temp, triping question.....again
bostonfan49
538
Essex Jct. Vermont
So My M55 continues to trip if I am in Fan 3 or higher AND in feed 2 or higher. If its cold I am in Fan 3, feed 2 and combustion 3 burning Vt Pellets (very hot!) or Green Supreme...less hot! If I go to Fan 2 and feed 1 oe even 2, the high heat sensor does not trip.....but I don't get as much heat either! I check/clean the burn pot every day and do the monthly clean every week! Any suggestions? In 3 weeks I am getting the adjustible auger cover and OAK installed!!! I hope the cover plate helps! Bill
Looks like you need to get a rush on the adjustable auger cover! Too much fuel to the fire and poof!
In the meantime get some other fuel that didn't trip the hi limit. Just to get by with until you get the parts installed!
keep us posted.
Thanks J-takeman......I figured someone would say that! According to Enviro, when the auger cover plate goes on, they are suggesting that the cover be set at the bottom setting (smallest opening) if I am going to continue to burn hot pellets. Bill
