New to pellet stoves. New Meridian stove installed 2 weeks ago. It has been working great until today.
I fired it up this morning and it went through it's cycle. Fan came on like usual after it heated up. I always have the fan on after that. I walked through the living room and noticed the fan was not blowing as hard as it usually does.
I pressed the fan button and it turned off. Pressed it again and it came back on...but now at even less volume. Then I noticed a strange smell. So, I shut the stove down.
The stove is new, so the fan shouldn't be toast already. ? I called the dealer, but they are probably closed all weekend.
The only thing different is I plugged the stove into a outlet mounted surge protector. Could this be causing my problem?
Thank you in advance for any tips or suggestions.
