Dune said:Could you clarify your question?
pen said:If you push air from inside the house to outside of the dwelling, that air needs to be replaced somewhere by cold air filling back in through outlets / door jambs / etc. If it's cold, it would take a heck of a fan to make that work since the cold air outside is much more dense than the warm air in your house, and the cold air wants to come in.
I think it's a better idea in general just to try and get the air within the dwelling to circulate well.
pen
jeff_t said:If you mean blowing air out of the house, it has to be replaced by outside air someplace. I'd say you're looking at a net loss.
James02 said:jeff_t said:If you mean blowing air out of the house, it has to be replaced by outside air someplace. I'd say you're looking at a net loss.
I figured it wouldn't work, but I wanted to maybe start some kinda buzz. Eh, I'll try harder.
James02 said:Dune said:Could you clarify your question?
Sure, if a window fan is blowing out in a colder room would it draw the warmer air into that room. Its understood that you would blow warm air out in time. Just kicking around some ideas is all.
bluedogz said:James02 said:Dune said:Could you clarify your question?
Your avatar indicates a firefighter... if so, you already know how positive pressure ventilation works. Move the cold air (from outside the structure) to displace the warmer air from inside the structure. For heating the house, I find moving cooler air towards the stove (in my case a tower fan tucked in a corner pointing at the stove room door) works amazingly well at moving heat all over the house.
