First post and one of several questions--
If you can burn a fire in a fireplace then why can't you use a wood stove with one?
When I moved into the house, there was a complete fireplace insert (with a "stove" back) and it just had a port on the back that didn't tie to anything -- it just blew out it's smoke through the damper.
I plan on completely enclosing the front of my fireplace with steel (from the back for a perfect seal) and then running the stove duct through it toward the damper. The stove will stand in front of the fireplace -- not in it. And I imagine I should have "some" small fresh air holes in the bottom of the plate? Not many though?
The chimney will be cleaned and I'm hoping I'll be ok -- at least for this winter -- if I need to improve. I'll do it next year.
I want an EPA stove and this fireplace is fantastic, solid limestone and nothing but concrete everywhere -- no studs of any kind nearby.
I'll try to get "some" pipe up the chimney but the damper is a large rectangle -- don't know if it's possible and if it's a pain, I'm dropping it -- don't know why just a cover and the pipe going through it won't work.
If a fireplace fire can be pulled through a damper into the chimney, I don't know why stove smoke won't either?
