I am re-installing our insert into a different fireplace and the flexible liner from the old installation is a bit shorter than needed to exit the top of the chimeny in the new installation (about 10-12" short). Thought about adding an additional section of liner to get it to clear the top tile, then I stumbled upon this statement on page 6 of the Ventinox installation guide (http://www.protechinfo.com/mc_images/category/45/2050.pdf):
There is a picture in the pdf link above, but in essence, the liner ends short of the top of the uppermost clay tile, insulation (Thermix) is brought up to within an inch of the top of the metal liner, then mortar seals the last inch between pipe and clay tile. I have ss caps for both the 12x12" tile and the 8" liner. Am planning on poured insulation regardless.
Guess the questions are:
1) Will this adversely affect the draw (chimney about 14' to top of stove, center of house, higher than roof peak) vs having liner itself sticking out w/own cap directly attached?
2) Risk of freeze damage if water can pool in this cavity? If so, should the mortar be sloped toward the ss liner so that any rain water that gets by the cap or condenses on the cap and drips off will run down the liner?
3) Anyone installed this way? Happy with performance?
Thanks.
3) Masonry crowns with a clay tile and any UL listed rain cap
... Fill the gap between VENTINOX® and the tile with TherMix® and seal the last
inch with mortar or crown mix. VENTINOX® may be terminated anywhere within the tile, as long as it protrudes
at least four inches into the tile. Attach a UL Listed rain cap to the clay tile.
Thanks.
