Question 1
Central Boiler and Alternative Heat Supplies have a good selection of forced air, water-to-air coils:
(broken link removed)
(broken link removed to http://www.altheatsupply.com/index.php/shop-by-needs/outdoor-wood-furnace-parts/water-to-air-exchangers/120-000-btu-water-to-air-heat-exchanger-1025.html)
Anyone else I should look at? (Preferably a Canadian company..)
Question 2
I've read it's good practice to remove these things in the summer... but how bad do these coils affect the efficiency of the furnace when running in NG/LP?
Question 3 (for the controls freaks)
How critical is it that LP and the 'zone' are never on at the same time? I'm wondering if I need a discrete switch between LP and the Boiler?
I was thinking of using a water temperature switch set at (lets just say) 130deg*
If (Boiler = ON) and (Temp < 130) and (Thermostat Contact = Closed)
Use LP, Zone On**
If (Boiler = ON) and (Temp > 130) and (Thermostat Contact = Closed)
Use Boiler, Zone On (obviously)
If (Boiler = OFF) and (Temp < 130) and (Thermostat Contact = Closed)
Use LP, Zone Off
If (Boiler = OFF) and (Temp > 130) and (Thermostat Contact = Closed)
Use LP, Zone Off
*with adjustable deadband
**My thinking was that if the boiler is ramping up, is it a big deal to have some circulation to help get the water up to temp?
Question 2
Use LP, Zone On**
Use LP, Zone Off
Use LP, Zone Off
