The article indicates that the batteries do work to even out the grid but currently are too expensive, except for some parts of Germany and Denmark in the Euro zone. The tipping point on current economic viability is at electric rates of about 30 euro-cents/kwy, or about $0.35/kwh US. What was also interesting is power management with customers to shift usage. When I talked to our utility about better home power management on a voluntary basis, the utility had no interest.
We offered to do similar kinds of things. Washing and drying clothes, operating the dishwasher, using hot water, even many kinds of cooking and oven uses, and much more can be scheduled to shift demand to even out the grid.The Nice Grid pilot has also experimented with "demand response" systems to use discounted tariffs to encourage citizens to use more electricity when sunshine is abundant and less during winter evening demand peaks.
Some 200 households signed up to let ERDF temporarily switch off their heaters or hot water boilers during winter evening peak consumption using the new "Linky" smart meters which France plans to roll out nationwide in coming years.
Another 70 customers signed up to receive an SMS warning the day before an expected sunny day so that they can benefit from midday power prices that are 33 percent lower.
"I switch on my washing machine when the sun shines," Carros resident Lara Muzzarelli told reporters in her red-stone villa.
The article mentions LiIon... I wonder if the economics would be more favorable if they used old fashion lead acid cells?
When I was looking into power outage backups, I did some pricing comparisons for each. The lithium ion batteries cost a lot more up front, but they've reached the point where the manufacturers are now claiming they'll last quite a few more cycles than the lead acid. The result is the life cycle costs of the two seem to be very close - around $0.50/kWh.
Interesting, I did not realize that the cost gap had closed so much... although I guess that is not surprising now that I think about it considering how far Li battery prices have fallen.
I was honestly suprised when Tesla came out with the power wall... as traditionally LiIon' biggest benefit has been the high energy density - making it a natural evolution for traction power applications in any vehicle, but not as big as a benefit in static power reserve where the weight of lead batteries is irrelevant and they are so cheap you can just compensate by buying more capacity.
Now here is the part I dont quite follow... I know its easy to stretch LiIon batteries to very long cycle lifes by limiting the discharge depth, and never fully charging (using just the middle from 25%-75%). Ive seen references that using only 50% of capacity this way you can boost cycle life from the typical 300-500 in consumer devices up to a couple thousand (Ive seen 4k referenced as the theoretical ceiling with charge capped to 3.92v/cell or 72%). This is better than lead which might manage 1000 at 50% DoD....
But what about calendar life?.... deep cycle lead optimized for storage like the kind sold for off grid solar can last 5-10 years or more... but LiIon seems to loose capacity with age a lot faster and even treated gentle most of the commercial batteries ive seen struggle to last longer than 2-3 years.
Iam, based on your comments, is this the point where rapid response batteries come into play? ... to quickly absorb excess power and just as quickly supply additional power when needed? BTW, those li-ion starting batteries are pretty amazing.
If you and 1% of Minneapolis have 8 kW arrays that get overshadowed by a giant cloud, things are probably ok without backup, as long as the rest of the supply and demand picture doesn't change, but if 10% of the households in Minneapolis have 8 kW arrays and the same thing happened, it's probably going to cause brownouts.
Is that much different than the effect if 10% of the grid users cycled their electric dryers and electric ovens (or electric central heat) on or off in the same time window as the cloud passing over?
Take a look at http://www.gridwatch.templar.co.uk/france/ - lots of nuclear power, but they cope with the difficulty in load-following by having a lot of interconnectors and a lot of Hydro. Their demand is also surprisingly flat - presumably the result of metering decisions over the years.The high nuke % on the French grid will make RE integration harder, due to its lack of throttle-ability. Indeed, high nuke penetration is almost as difficult as high RE penetration, when it comes to load matching, but for the opposite reason. Most pumped storage facilities around the world were built for diurnal load balancing nukes.
Bottom line: it makes sense the French would be on the vanguard for advanced storage technology.
