Gas Fireplace Shuts Off in Minutes
FraserJim
3
Fraser CO
Gas fireplace shuts off a couple of minutes after turning on. 20-year old RH Peterson, SPK-20 Valve, PT-5 pilot kit (8,640’, special for high altitude). I have replaced the thermocouple every 3-4 years. It will start shutting off minutes after being turned on. I can reignite immediately but will shutoff within minutes.
The original burner pan came with a metal flame diverter to shield thermocouple. Pilot and diverter mount at the back of the pan. It has disintegrated a long time ago. I have fashioned shields that alleviate the issue for months once it starts acting up.
When I pull, pilot, grate and pan, there are deposits than look like iron ore. I am presuming that they come from the gas.
I have tried to route the thermocouple lead as far away as possible from burner.
I am presuming that the thermocouple deteriorates over time (deposits?) and will start producing either an over or under voltage when heated.
I am looking for suggestions? Another brand or type of thermocouple? A pilot that mounts on side of pan vs. back? Whole new gas valve / pilot assembly (high altitude jet?)?, etc.?
  • [Hearth.com] Gas Fireplace Shuts Off in Minutes
What color is the flame at the pilot and also the main flame. Looks like soot.
Pilot and burner solid yellow. Flames on gas cooktop and boiler solid blue. Our gas utility a couple of years ago was maintaining the area service and we were getting some yellow, but it cleared up after a couple of weeks.
How can you get more air? Is there something plugged? Was it ever blue bottom with yellow tip?
Good questions. Don’t remember blue with yellow tip, but pilot is supposed to be correct one for my altitude. Does anyone know of a manufacturer who does better at altitude? No electrical near by. Are there any battery powered pilots?
Using a long, narrow screwdriver, turn the pilot adjustment screw slowly clockwise to reduce the pilot fl ame or counter-clockwise to increase the fl ame. The adjustment screw can be turned so that the pilot fl ame is completely extinguished. Some tightening of the screw may occur during adjustment; this is normal. The pilot flame should be a soft blue color with slightly yellow tipping that encircles the thermocouple tip.
Page 5 of
You should replace all the parts that need to be replaced, or buy something new. It's already ready for it's retirement.
