I have 2 Harman P61 pellets stoves. One of the stoves is way hotter then the other when idling. I have the thermostat set as low as it can go on both stove so both stoves are essentially idling with a very minimal flame. If I measure the temperature on the side of one stove it is 160F. The temperature on the other stove in the same spot is 290F.
I have had this stove for 25 years and do all of the cleaning an maintenance on it myself. I can't figure this one out. It feel like there is too much airflow in the stove causing the pellets to burn really hot.
This is what I have tried so far.
I have cleaned the stove completely,
Cleaned the inside of the burn pot.
Cleared all the holes in the burn pot.
Replaced the ESP.
Replaced the door casket.
swapped room temperature probes between the 2 stoves.
swapped the doors between the 2 stoves.
I tried different feed rate settings, it is set at 3 now.
Replaced the ESP.
