Hard-to start problem
LAndrim
99
Outside of Philly
Newbie here...getting educated and need some advice on hard starts.
I have a Tiara II by HeatnGlo, about 4 years old. Clean it every year before we start up. This year, it is VERY hard to start. When I click the start button on, nothing happens. I have to click it sometimes 5, 6, 7 times before I get the flames going.
Does anyone know what is going on? Dealer was not sure what the issue is, said it might be static electricity...I'm not so sure about this.
Please help. Thanks, guys!
Click what start button? The switch on the stove is toggle on / off. Is that what you are referring to?
Sounds like the thermopile might be getting weak. Does it ever shut off by itself while running? Other possibility is the switch wiring has a loose connection.
+1. Also check the t-pile connections. If the screws at the terminal block are not tight, intermittent ignition can also happen.
Sorry, yes, I switch I referred to is the on/off switch. Yes, it has shut of twice while running. Would this be the thermopile you referred to? First thing I did was check all the wires to make sure they weren't frayed or loose, so they are all in good shape. Would you advise replacing the thermopile? Thanks much!
ruth140 said:
does the pilot light stay on?
Yes, there is no problem with the pilot, just the need to turn the On/off switch at least a half dozen times. All connections are tight.
Thanks!
not sure but you might need a new switch. if you "jump" the wires and it unit turns on and stays on...then you can determine that its the switch itself thats bad
Possibly. It could also be the wiring TO the switch...
Thanks all...
I'll try all your suggestions...one of them has to work. Again, you guys are great..much appreciated!
