Harman users -- What are your settings?
Eric D
22
Southeast Mass
I keep tinkering with my feed rate trying to minimize the ash on the pot....seems to be burning good on stove temp 5 with a feed rate of 4...Trying to heat a 1800sq ft area - 11 outside and i'm running at 67 now; blowing through pellets though....
Room temp manual just started that last night from another thread
feed-4
dist. blower mid point
temp 4.5
12 outside
74 inside downstairs and 72 upstairs
no oak i can feel where the drafts are tonight
I'm running on Room Temp Manual tonight - trying it out based on advice I got from a thread yesterday. I have it set for 70, feed rate 4, blower on high. It's 72 first floor, 68 bedrooms, 5 outside. We'll see how it does.
Room temp manual 72 degrees, feed rate 4, blower on mid position. Burning Turman's.
Stove Temp Auto feed rate 4 Fan on med low and temp on 65. Its 18 outside 72 inside and burning GAPS. filled the hopper this morning at 6 am still have 1/3 left so i should get around 20 hours out of the bag
Room Temp, Manual, feed rate 4, Fan all the way over, temp set at 72-75. It is -4 outside and the rooms by that stove are 70 to 76
Room Temp,Auto Feed Rate 3 1/2 Temp. set at 70 Deg. Fan set at the 12:00 O'clock Position .Stove room Is 70 deg. Back rooms are 68 Deg Upstairs bedrooms are 67 deg.(Expanded Cape House 1500 Sq. Ft.. Outside Temp in Plaistow N.H.Is 12 Deg. Burning Okies,Cubex and Vermonts NO OIL. Yippee
stove temp on my p68, fan high and feed at 4, heat dail set to 3.5, it's warm out next to other post at 10 above and i'm burning VT's, I find these pellets are good and hot. First floor is about 74-78 depending were I am.
Feed rate at 4.(Set it and forget it)
Running in Room Temp with igniter switch in manual. Fan on High.
-6 here this AM. Keeps a steady 78 in living room and 64 in upstairs bedrooms.(Insulation issues)
Yeah we are going through 1.5 to 2 bags a day when real cold. Use 1 to 1.5 when temps are above 15 or so.Burned about 2 tons out of 4 since mid October.
3 months down 3 to go so pretty much on schedule. Warmer weather coming next week......
I'm running about the same after reading the same thread :)
Room temp manual. Temp at 73, feed at 3.5, half way on the fan. Still 76 in here outside 1.
0 degrees this morning. Room Temp Auto @ 72. Feed rate about 3.5. Blower high. Burning Okie Black Hills. Its about 75 in that room and about 67 in the far reaches of the upstairs rooms
Room temp manual. Fan speed dial at medium. Feed rate dial at 4. Temp dial at around 75 but I let the wireless thermostat control the room temp. 69 in the morning for a couple hours and in the evening for a few hours. 63 at night and while we are at work.
Room Temp Auto 70. Feed Rate 4. Fan low. Heating 1000 sg ft. 9 deg last night. 74 in the main rooms 64 in the bedrooms (keep doors closed). Perfect.
Room Temp Auto 60 during the day.
Using about a bag per 24.
can anyone post that thread that you've been reading, like to give it a try myself
Room temp manual. feed rate at 4. fan on low switch but max on dial. loosing temp upstairs(1500sq ft) as we speak as the temps outside about -36F!!!! oil furnace kicking in to help$$$. burning cubex only...
Room temp Auto. Temp set to 70::F. Feed at 3.5. -4::F outside, 70::F in the stove room. 69::F in the adjacent living room. Both rooms in a walk out basement on a slab. Burning two bags of Cleanfire Hardwoods per day... Oil is for DHW only...
Room temp manual set to 75, feed rate 4.5 - 5, connected to a set back thermostat. For last week or so, things don't seem to be working as well as they were, since no matter what I try with the feed rate, pellets in the pot don't change. Flame seems lazy. On the other hand nighttime temps have been hitting -2 to -8 and highs around 10 for the last 10 days. Going to try and clean the stove pipe this weekend, assuming I can get on the roof and over to the pipe, without crossing snow, since I know that will not end well for me.
harman lover....thanks for the thread. i run stove mode with feed rate @ 4 and rarely does that change. right now with the single digit temps at night i run on setting 5.5 and it keeps 2200 sq ft nice n warm.....since owning the stove for 4 years now the electric heat as not been turned on
>Here< they are...
990 squarefeet, low hill & Gulf Stream, old stoned city house + medium insulation...
Au revoir.
Basement: P-43: Auto, stove temp # 2, feed rate # 4
Family room: Accenta insert: Manual, room temp @ 67, feed rate # 4
House is a comfortable 72 degrees
