I was given a US Stove circulator type stove that I repainted and put new firebrick in. I installed my black pipe and stainless chimney in the shop and was all set for pure comfort this winter. The only problem is it doesn't seem to be heating the shop all that well. Here are the particulars:
Shop size: 24x36 insulated walls-open ceiling (for storage). 6/12 pitch roof.
Wood: mix of sweet gum and oak-cut last winter
Two ceiling fans in the rafters set to blow up
I'm wondering if I should build an enclosure to seal off the chimney hole through the roof so heat won't escape up thru the flashing vents?
I also have a ridge vent cut in the top of the roof. Should I cover those holes with insulation or other products in the winter?
The stove has a blower option available. Should I look into one of those?
I know the easy answer will be to install an insulated ceiling but I really need the open storage space. I've seen much larger buildings heated with only a stove and that's why I'm a little puzzled here.
Thanks for your help!
