Pellet stove 25-PDVC when I turn the stove on the room blower turns on at the same time full speed. We had a a power outage while it was running and when we got power back it was not running right, Would a faulty Heat sensor be causing the problem? It starts and runs but will shut down after a few minutes with an E2 and the whole time the room blower is running at full speed.
If the stove is unplugged and is plugged back in the room blower will start running again at full speed before I even hit the on button. The stove was plugged into a surge outlet from Home Depot.
Checked the manual quick looking for a snap disc that might be at fault but it appears that this stove has a thermal sensor. This would be what I would be looking at as something is telling the blower the temperature of burn is high enough to transfer heat... Good luck.
