Finally got around to changing the plugs on the 3.3 Caravan - way north of 100K miles. Always ran well with no skips and good mileage, so the job kept on getting pushed off in favor of something else. The plugs were so old that lots of rust had formed on the front 3 - more on that later. If you don't have a lift, about the only way to get at the 3 back plugs is to remove the wiper tub - kind of a PITA, but not a tough job. So that went ok, and the 3 back plugs (not much rust) were easily changed out. Moving to the "easy" front plugs, the first came out without any fuss. Then came the middle plug. I saw the rust on the other front plug, but didn't think about it too much - I've had other rusted plugs and nothing bad had ever happened in the past. Well a moderate amount of torque didn't move the middle guy, and so I applied a bit more. I have no idea how much force I was using, but didn't think it was anywhere close to a "career high". Anyway .... SNAP. A quick glance showed the plug completely sheared off - the entire top of the plug was still in the socket. The air left my lungs, and all the blood drained out of my head. I knew this was very bad - I wasn't about to drill the ceramic to make room for an easy-out because that might risk busting through, and sending a pile of shards into the cylinder. And without one of those $10,000 shop manuals, I wouldn't think about tearing apart the engine. So it was probably going to have to be towed, and need some expensive shop work. Then I decided to have a close look at the half plug still in the engine, and as I gently poked the ceramic and electrode, it moved! My first thought - the whole thing must be broken up and small pieces have already dropped into the cylinder. So in my mind it had gone from real bad to much worse. Then I thought maybe it was just a surface chip, and I could just lift it out. Well, unbelievably, when I started slowly lifting the loose ceramic with a blade, the entire guts of the plug came out!. It was completely intact - not even so much as a small chip missing. After vacuuming out the hole in the plug and everything around it, an easy-out made short work of getting out the metal shell of the plug. Once everything was back together, I did one of those pointing things that the baseball players do, and fired it up (hoping that no stray shard of metal had dropped down in). A few hundred miles later, everything still sounds good, so it seems likely that nothing real nasty got down into the cylinder - a very fortunate outcome. Anyone else ever see or hear of anything like this?
