If you have an existing wood stove, but want to extend the warmth to other parts of the house, with airducts it's easy, simply add a fan to blow air from near the wood stove into the air duct, but assume your house don't have air ducts. so it has to be via steam or hot water.
- What boiler pipes or heat exchanger will you use to extract heat from the hot flue?
- Is it OK to simply hook into existing steam heating pipes of the house?
- How will you control the water flow, such that flue exit temperature is above 300°F to avoid creosote condensation?
