How to add a boiler extension to a wood stove?
monteville
346
Dallas
I looked at a neighbours HWT she said was making noises. Her husband had gotten tired of the water coming out of PRV pipe onto the floor.
He installed a shark bite cap on the end of the pipe then left for a week working out of town.
The hot tap water was steaming.
How to explain to a women her husband had created a bomb and left for a week without getting him divorced or worse. Lol.
I don't understand, it's roughly the same work as replacing the T&P valve. Most dripping T&P valves are not even bad, they just cannot fully shut because of scale invasion, could be closed by simply descaling with citric acid.
Not including this one, which might have a failed controller or temperature sensor.
I have renewed quite a few old water heaters the owners said "probably need replacement" by flushing and descaling. "wow as good as new"!
bholler
Chimney sweep
Staff member
Jan 14, 2014
28,473
central pa
Well yeah that's common practice don't forget to change the anode rod as well.
So no comment on the clear dangers of steam explosions
Yeah I really am not any sort of expert on hydronic systems. I am more stoves and chimneys. But I have been around them enough and have enough common sense to know the risks.
Il
my point is without knowing it he created a potential bomb. The temp was set to high, the tank was less then a year old.
If you’re building a hydronic system it’s very easy to leave a valve closed or install a check valve backwards, hundreds of things that can cause a serious issue. If you’re working on this homemade system at night, after a days work it’s easy to get brain fade. Then stuff goes bad really quick.
Reactions: bholler
monteville
346
Dallas
When should the anode rod be replaced? Is 1/2 diameter(1/4 volume, after scraping off the scale and oxidation) a good replacement time?
bholler
Chimney sweep
Staff member
Jan 14, 2014
28,473
central pa
Check with the manufacturer
brenndatomu
7,129
NE Ohio
He’s got it all figured out, until he doesn’t and he seriously injures a loved one or stranger.
IMO, dude is just trolling (again!) he won't be building anything...
Reactions: hobbyheater
