Looking for a repair of my Hudson River pellet stove 3 yrs old . The new auger motor still does not turn. Recommendation of someone in north shore massachusetts area I can't t seem to find any reset switches thanks
The high limit which has to be manually reset is on the back top of the heat exchanger, left hand side looking at the stove there is a small red reset button in the center of that switch, press that in and you should feel it snap back in place. Then hit the on/off button to turn the power off and then back on.
This is the likely cause only if the stove stopped running with a fire going.
The normal cause for this is a failed, failing, dirty convection fan (At least that is what the manual says. I take exception to that but here is not the place for the debate. ). What has happened is the stove exceeded 250 degrees on the heat exchanger where the snap disc is.
The other cause is a vacuum error due to the combustion fan not starting or ash in the plumbing somewhere reaching the point the stove can no longer breath.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
