This morning my lower auger motor stopped turning,.. so I purchased two (2) new auger motors from a local parts distributor,.. I figure Id do both motors at the same time. The install went smooth,.. fired the stove back up,.. everything going smooth except I noticed the flame height much higher,.. I turned heat and fan settings down to 1-1,... still running unusually hot,... back the trim setting down to 1-1-1,.. STILL running crazy hot,,.. so I timed the lower auger with a stopwatch (because I can see that one),.. I know they're supposed to run at 1 rpm. The bottom auger is running just over 2 rpm with all settings as low as possible. So with the room creeping up on 80 degrees, I have shut the stove down until I can figure out whats going on here... it appears this guy sold me 2.4 rpm motors.!!
