Just installed a Jotul Castine and have a question on the clearance. Its a corner orientation with brick on bottom and sides. There is plenty of ceiling clearance but the back corners are approx 5.5" from the brick. Jotul manual says 8" with single pipe and no rear heat shield for protected wall. I checked and the brick has a 1" gap from the wall sheathing, but it also has some type of non-paper backed insulation in the gap. Note that the previous owner had an older pre-EPA stove installed at this location and used it for years. My clearance with the brick is easily 8" from the combustible wall, but Im worried about the insulation. My pipe is straight up 3', 90 turn, through wall, 90 on exterior, and 15' vertical run. If I put a 45 elbow and a short horizontal run at the interior 90, I can slide the stove out from the wall. How would that affect my draft? The problem is that the pre-existing hole in the wall (brick on both sides) is very close the corner. Thus the need to get the stove close for an up and through with the one 90 elbow. Hopefully that is not too confusing. Thanks!
