Stove temp was 500 . First time getting the secondaries to light . Pretty neat to watch . The video is blurry thats my fault I shot it with a digital camera and forgot to set the camera to autofocus http://www.youtube.com/watch?v=uYI2gJjSF9s
Hey tooth, nice video. Are you running with primary air closed down all the way? I had mine running at 500* with it shut down last evening. Incredible blue secondaries about 2 hrs into the burn with maple shorts and uglies. I can't wait for a full load of oak or cherry when the real cold hits. Still learning when to start closing the primary down, but I'm getting there.
Yes I closed the air all the way . I started a top down fire with 3 small splits , 2 medium , and 2 full size pieces of poplar . Once the little stuff was burnt down to coals and the largest splits were burning i added 1 more medium sized split , once that ignited the stove reached the 500 mark and i started to close the air down the secondaries lit off when it was about 90% closed . I closed the air all the way down and they stayed lit for quite awhile .
I have had no luck with top-down after a few good attempts. Bottom-up is working great with the start up lever in the door. I am amazed that it runs steady at 500* with the primary shut.
I watched the video ( from Canada ) in one of the other post about top down fires . I made the news paper knots ( i think i used 4 knots ) and put in 2 small pieces of fat wood . Lit off the newspaper and shut the door after 5 or 10 minutes i closed off the start up air and the fire took off pretty well .
It was never a problem when I had the little brother F-100 last season. My wood is 12 -18% MC, plenty of kindling. It has been damp with low pressure, maybe part of the reason. But, bottom up - off like a rocket. Go figure.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
