I heard there was a fix for the front door ash out pouring issue. I've looked.... And looked... No luck. If such a link exists would someone mind "hooking a brotha up"
Thanks,
sootfoot
Thanks,
sootfoot
Thanks,
sootfoot
I believe the only available fix is to use the side door... At least that's what I do.
I use the side door 90% of the time but still, it would be nice to be able to use both. I would mainly use the front door for building a fire when I have no hot coals. Or even cleaning the stove out & cleaning the glass. I can live with it, however it's a super dumb problem to have with such an expensive/ high quality stove.
Note, the side door on the Oslo is not supposed to be used in corner installations.
The F600 has the same caveat. The side door is supposed to be locked for corner installs. This is a clearance issue.
As I recall, with the door closed I have the correct clearance from the corner to the wall, and I have a rear shield. But ,yes the door does only clear the wall by a few inches as you swing it open. That's strange that they would consider that an issue. I guess the door is hot when you open it but you don't run. It open. Besides the ash issue, I only use the side door because I have seen logs rolling out of front loaders that that are east west orientated.
Thanks Be Green for the explanation.
